LW1DSE
Hi all folks. I owned this vintage rig near the start of 2025. It was out of service, tubes and knobs missing. Lytics look good, mainly the PSU unit, some RCA jacks missing, the S-meter appears OK.
Some tubes were hard to reach and was substituted with newer with more gm (gain). The dial mechanism is complete but very hard to move. The device that move the cores into the RF coils was partially broken. Some resistors out of range, but not too far from proper value.
First work was to remove the 'lytic can and place under the chassis, fresh Jamicon 100uF 160V units. The original 4 diode rectifier was replaced by a molded 4 pin 1A 1KV unit. Once did it and using current limited power supply (aka a filament lamp 300W 220V in series in the live wire) I started the unit, and some noise come from the (external) speaker.
Once the devise looked more or less doing its job, I started modding it. The first target was to remove a npn germanium transistor acting as audio preamp in the CW and SSB modes. It and and all its circuitry, completely dismanrled. All the detectors and main audio channel is reworked. Secondary channel for remote operation, disassembled completely.
At first, the audio output tube (6BF5 designed with low gm for vertical deflection) replaced with a 6EH5, 3X the gm of the original. Socket non compatible, so except heaters, all other connections changed. The 12AX7 audio preamp is replaced with a triode-dual diode 6BN8. Cathode resistors of both removed and grounded directly. 6BN8 triode now uses 10M grid leak biasing and 0.001uF coupling cap to the audio pote.
All germanium diode detectors, completely deleted: the 4 of the product detector for SSB & CW are now a 6JU8A quad diode like 2u 6AL5 in a single bottle. Socket added to the chassis. Also diodes for AM and AGC were taken off, another 6JU8A acting as peak to peak detectors (voltage doubler) recovering twice the audio signal than a half wave detector.
