Hi All
Im running a ICOM 718 into an Antenna Tuner connected to a WINDOM 40 Meter antenna
The interesting thing is, the antenna via the Tuner can actually do a great job on 80 meters as well...
but not all the time....
there are several threads to my question so please have some patience with this....
Im running 75 ohm cable to the antenna.. more because it was available at the time and seemed to give a better SWR
Should I change this to RG58?
I have no choke in line but part of the cable is buried underground... should I still put a Choke in line regardless?
The Antenna is quite low around 8 meters off the ground [if that]
The reason I am not 'letting up' and just transmitting on it for 40 meters which is what it was designed for, is at one point during my tests.. I had a magnificent signal output on 80 meters with several stations.. now I cant seem to get back to it....since I have changed and fiddled with antenna lines etc
any simple advide re cable types etc would be useful
73's
VK7FMMM
73's
VK7FMMM
