My QTH does not allow of home-based radio so I operate solely portable. Given the English weather, I need a more reliable fix of morse. So I use morse-over-the-internet from home. In fact, that's how I got started with chatting via morse, once I'd learnt how to form the letters using my Morserino-32.
My favoured vehicle for morse-over-the-internet is CWCOM.
If you already have a morse key, you can connect it to your computer with a simple adapter cable. The adapter cable consists of a shortened audio cable with 3.5mm jack socket; wired into a DB9 breakout; which plugs into a serial-to-usb cable. No soldering required if you use a DB9 "breakout". Sounds complicated but it isn't, as you can see from the photo (I don't use the opto-isolator any more).
Or, if you have some soldering skills, you can wire your key through an old computer mouse. See photo (ignore my "tongue depressor" straight key!).
If you don't have a morse key, just use the down arrow of your keyboard, or left clicks of your mouse.
Full instructions on how to connect are at
https://morsepower.blogspot.com/p/blog-page.html
Gerry, the administrator, is very helpful and will get you started, no problems.
The experienced guys on there are very tolerant of slow speed and beginner's mistakes. The on-screen decode means they can go as fast as they like (generally 20-25 wpm) and I can still understand them. The ex-professionals find it difficult to slow down to my head copy speed but I can still enjoy chatting with them.
There are other learners on there that go at my speed (13 wpm) or slower and I find "head copying" with them very satisfying.
- Very low set-up cost.
- No QSB, QRM or QRN.
- World-wide contacts.
- between operators of widely different speed.
