Morse Key Kit from eBay
It must have been the Morse Key collector in me, but I've just purchased one of these kits from eBay...
They're produced by M0BMN of FISTS fame.
Costs are £5.50 for the kit plus £1 p&p.
I can already see a mod being needed to the control knob screw that stands proud of the top, but other than that it should be fun to try.
They are so low profile that you could put one in to your shirt pocket to use portable.
73, Mark... 👋
Interesting, a definitely a portable key.
But why do they advertise it as suitable for novices? It has no adjustments which must make it somewhat compromised in performance. Surely a novice needs a halfway decent key to get started on before they can cope with something idiosyncratic...
I'm guessing that the "suitable for novices" comment equates to 'low cost' and 'simple'. I've seen many keys over the years marketed as being "ideal for beginners", "great for those just starting out" etc. And they all have the same qualities of being low budget and using more common materials.
You could always try asking M0BNM, I think his contact details are on the FISTS website...
Sometimes too many adjustments mean that folks spend more time messing around with settings that actually practising!
M0BNM also markets these kits and others under the "Phoenix Kits" brand. All the kits are intended to be simple to build and use, apart from the Morse tutor which is a little bit more involved. That kit is called the FMT (FISTS Morse Tutor).
73, Mark... 👋
I suppose it is very simple, and as such is easy to replace or fix if used in a club setting for training.
It might do as a pretty simple and robust emergency key, you'll have to let us know how you get on with it Mark.
Paul got in touch to say that he won't be able to post the items until Monday, so possibly it will be the middle of next week before the kits arrive.
Oh well... ☹️
Well, about one week after ordering the kit it arrived!
I actually ordered two but have only built the one key up.
The key kit is packed in to two grip lock bags, one contains all of the assorted hardware, the other bag has the two PCB key parts, the base and the arm.
The base and arm are amazingly solid little items, looks like FR4 PCB material so very strong. For rigidity both the arm and the base PCBs use almost 100% copper coverage, with only the minimal amount removed for isolation between tracks.
You have to solder a small 3.5mm socket, and also a capacitor that I presume is to debounce the contacts. Simple idea but it works really well.
The only tools required (apart from a soldering iron) are a small Philips screwdriver, and either some small spanners or maybe an adjustable wrench. You can of course use some pliers, but be careful not to 'chew up' the brass separator posts.
The whole assembly including soldering took about 45 minutes taking it steady and not rushing (also I was taking some photographs along the way so that slowed things down a little).
The kit comes supplied with a red spacer washer, which if you prefer a larger contact gap you may fit. Actually mine had two of these washers in the parts bag. Once the key is assembled you try it out and see if you need a bigger gap. I found that even just gently resting my finger tips on the key made it close, so I inserted the spacer washer. Perfect!
Because there were two spacer washers in the bag I though I would see how it felt fitting both. Bad idea. Even though the spacers are fairly thin I found that with two fitted the gap was too much and took conscious effort to manipulate the key, and just seemed way too large. When reduced back to just one spacer all was excellent again. :p
For what it is, and how cheap they cost, the key feels great, and works really well.
There is no connecting lead supplied, but any 3,5mm audio lead will work (I have some here that were two for ?1 and they perform great with it). Because the lead is pluggable it's possible to carry a few spare leads just in case, or maybe have differing terminations on them, say 3.5 to 3.5, then maybe 3.5 to 6.25mm etc.
I'm not joking when I say that I really enjoyed building the key, and was really pleased with the end results! I tested it out using a Datong Morse Tutor as a practice oscillator, mainly because I know that the Datong is NOT very forgiving of contact resistance, so poor contacts on a key will generally result in a broken or wavering tone. There was none of that with this key! :p
It keys well (trust me, I have over 350 other keys to compare it to!), and would say it 'feels' a little like a cross between a 'strap' key (which is what it is essentially), and an old time high speed telegraph key.
So to sum up, a great little key, very solid in design, nice and slim so easily carried for portable use. For the price I think it's really good value, and well worth the money.
The only slight niggle for me is the screw head that sits proud of the control 'button'. Maybe a countersunk screw would be better (so that the head would be flush with the button surface), or else perhaps some kind of cover to round off the top of the button and add some grip for the operators' fingers. (I have an idea for this which I will try out and post on if it works out OK).
73, Mark... 👋
Nice! looks good, and I've been thinking about this little key since I saw it in Keynotes.
May have to get one...
Had a look around the attic this morning and dug out some furniture feet to use to mod the kit-key from Phoenix Electronics.
Had a sort through various types, then spotted some nail on ones that looked just the job. Had to heat up the nail with a soldering iron then use pliers to remove it while the plastic was still soft.
Next, used a 6.5mm drill to open up the hole where the nail had been so as to fit over the screw that sits proud of the Morse Key button top, and then de-burred the edges.
Finally, wiped over the back of the foot, and the original Morse Key button so as to degrease them. Used a small piece of double sided tape to attach the foot to the button.
Job done! :p
Looks a lot better now 'in the flesh', and feels a lot better too!
That certainly looks a lot better.
I've only ever seen hard knobs on straight keys. Do you find that the sponginess of the felt decreases the tactile feedback at all?
Although the feet look like they may be soft in the photos, in actual fact they are fairly tough items. If you are not looking at the key you would swear that the button was cork. It has a kind of rough texture, and you can tell it is not solid by the sound of the material as you pass your fingers over it. I did just have a go at squashing it down but it's quite solid.
It worked out just right for 'feel', as I can rest my index finger on the top, and my thumb and second finger naturally then rest on the slight 'flange' formed where the felt insert enters the plastic cup base section.
I did look at using one of the all plastic ones I had laying around, but I found them to be very slippery, and with a rounded edge it would have taken some effort to keep hold of the Morse Key button.
As it is though, this mod looks quite good and has improved the feel of the key immensely! :p
