CT2GXW said:
Thanks Mark, I will consider building the air variable myself. Then I need to sort out the motor drive system for tuning, which I will probably do with a stepper motor.
To make one of these antennas for a permanent installation is quite a task. No wonder the commercial models are so expensive.
You could use a stepper motor, but an easier way (which I've used a number of times before), is to use a servo (the kind used as actuators in radio control models), they have very high torques for their size, and have pretty robust gearboxes too.
It is possible to modify the servos by disconnecting the internal servo amplifier board and positional feedback potentiometer (just remove then both), then you can use DC to wind the motor/gearbox back and forth. The gear ratio is not normally high enough to give accurate tuning on a loop, so I normally add an extra couple of pulleys or sprockets to give a further reduction to the capacitor shaft. Sometimes you can get slow motion drives too, maybe 8:1 or 16:1 etc.
With a modified servo, pulleys/reduction drive, and a variable capacitor you have everything you need to remotely tune a loop. You could PWM the motor (which allows for a high torque but a slower speed than a continuous DC feed, this is how MFJ control their loop motors), or else you could use a really simple control system like I used sometimes in the past. Just a few batteries and four push button switches. Two switches give either positive or negative at one voltage, the other two give positive or negative at a higher voltage. The low volts allows for slow tuning, the higher volts for fast tuning (changing bands or going from one end of a band to the other). Also. you can tap the switches with your finger to give a kind of manual PWM output.
It may sound crude but it works. I used it to tune an 80m mag-loop I built in my attic here, worked fine. As an extra refinement I added two microswitches that were triggered by the position of the variable capacitor. So if the capacitor was fully one way it would open the switch and stop rotation any further in that direction. Same at the opposite direction of travel.
Once set up correctly you just give the loop some RF drive and press the up and down tune button while keeping an eye open for a dip in the SWR.
There's a design floating around on the web for an auto tuning mag-loop designed by G4WIM. That uses a much more advanced micro to control everything, and a stepper motor plus reduction drive for the 'muscle' of the system.
https://www.youtube.com/watch?v=BZ4HedpjqOY
It all depends how elaborate you want to get with the tuning control gear, but I think if you go too crazy with it too soon you miss the fun and amazement of using magnetic loops. Over the last forty to fifty years many of the loops I've tinkered with have just been made with sections of coaxial cable, and using old capacitors removed from MW/SW radios to tune them. No good for QRO power, but I don't normally run more than 5 watts anyhow, in fact a lot of my QRP rigs are only 1-2 watts at most, so flashover isn't an issue here.
I do have an MFJ-1788X loop which I think is rated at 150 watts or so, but again it only ever sees QRP levels of RF bd
