I'll go first.
I only have a Kent KT1 at the moment, which is fine as I've not actually had any on-air QSOs yet, being a noob who is still learning the code.
However, it's a heavy, solid key with a lot of adjustment options. I've set it to quite a small spacing at the moment when working with the practice oscillator, so there is little movement and pressure required to key down. I suppose that may change later, depending on how I get on on the air for longer periods of time.
It's definitely not a key to take out portable though, that's for sure!
