Actually, you can't see the keyer in the photo 'cos it's inside that old tobacco tin alongside a rechargeable PP9 battery.
There's an On/Off switch. And a "power on" LED 'cos I keep leaving it on (it goes into a dormant mode after a period of inactivity but there's still a slight drain on the battery).
I only wired up one of the control buttons because I don't need any of the memories. This one button enables me to program the K-16 using code letters keyed by my paddle. There's a speaker to give you audio feedback as you're inserting these control sequences. I recommend that you write the control sequence down because its easy to get lost in the middle.
Here's a good question (which took me a little time to figure out the answer to): if the speed is set to a lot faster than you can send, how do you enter the control characters to slow it down? The answer is that as soon as you enter the programming mode, the control code entry speed drops to about 10 wpm and even beginners can send a single character at that speed. Phew.
So, a bit of soldering required and a bit of a faff to adjust parameters. But it has a lot of functionality (most of which I don't use - just the Ultimatic mode and varying the speed).
And it's cheap.
Recommended.
And it's cheap.
Recommended.
