Hiya
As soon as I read your description of the symptoms I thought "Ah, DC-DC converter!"
He's correct about them not being available any more (certainly not from Icom anyhow). We have two of those sets in the workshop over here in the UK with similar problems and as yet we've been unable to track down any spares
Although it is possible for them to fail outright, it is also possible for them to develop an intermittent fault. Intermittent faults (in those units) tend to be caused by dry joints, and also by the failure of capacitors, causing the internal oscillator to stop running and hence no out put.
There's a -5V and a -33V output from the unit, the -5V is for the ALC and the -33V for the display (if memory serves!)
I have dismantled the units in the past and repaired them, but you will need a lot of patience/luck/time.
Keep in mind that it might not be the DC-DC converter, it could be one of the inputs to the unit causing the problem.
They are fine radios and well worth fixing if you do it yourself, but to have one repaired by a technician can cost quite a lot due to the time involved.
If you need a copy of the service manual for the IC-761 (in PDF format), I can upload one to the site and send you a link to it. There are no internal details of the module itself, but you can of course see what is connected to what externally, what leads connect to where etc.
The IC-751 used a similar system, but it was built around discrete components so much easier to repair. Again, it is worth having a look at that radio to get a feel for what the converter does, as it's a very similar system indeed.
I can supply the info on the IC-751 also if you need it.
