k3roj
The older we get, the more we realize how sometimes using the simple techniques are the best. Have tried many antennas over my 48 years as a Ham but recently happened to pick up the ARRL Wire Antennas Classics book at a local hamfest. Many of the dipole and other exotic wire antennas would never fit in my backyard but happened to turn to a page showing the Skywire Loop Antenna. It looked so simple and decided to construct the 40 meter Skywire. It is configured in a square arrangement with a total of 144 feet of number 14 stranded wire. Since each leg is only 36 feet, it fit nicely in my back yard. Of course the book said it should be 40 feet in the air but I used what I had, my two sheds, the rear of the house and a pole at the corner of my fence. It is only in the air about 15 to 20 feet but decided to check it out in the shack. Signals on 40 meters were booming in and right away made some contacts without any tuner. Then on 20 meters, there were several European stations on CW and figured I would need my rigs tuner to transmit. I use the Flex 5000A transceiver and it was showing only 1.8 to 1 SWR and went ahead and called an Italian station who said I was very strong. The same thing with a few other stations on 20 and decided, what the heck and tried 15 meters which was a dead band but my SWR was fairly good on 21.010 Mhz. 10 Meters was also OK to use. Not stopping there, I tried 52.525 where I have a friend who always listens there on FM. He is 15 miles away and said I had a much better signal than when I talk to him using an all band vertical.
I am very impressed with this simple antenna. I just wish I had the room for a 80 meter horizontal loop and envy those who can install one for 160 meters.
