I have 100 feet of RG-213 coax. I'll be putting up an 80 meter dipole 31 feet high. Looks like I'll only need about 75 feet of coax to feed the antenna. It will drop straight down to the ground and buried 3 inches below ground level as it leads to the radio shack.
My question is ~ "Should I use the 100feet of coax as is, or , cut it to the actual length needed?".
The 80 meter Dipole antenna is a Princeton bare wire at 123 feet long, and is equipped with a 1:1 balun at the feed-point.
Thanks Sage
Thanks Sage
