My knowledge about industrially manufactured antennas is quite low or null. From the very start of me at radio in 1987 when I got my LW1DSE call, I used to build my own aerials, and even my own rigs. However, many commercially available are based in the ever-deseiver adverticers. Anyone that has studied a minimum of Physics know that antennas don't gain anything, their gain is only
relative (from here the use of dB notation) over an isotrophic radiator (a conductive sphere), or a simple dipole. In fact, any antenna has looses: both resistive (in series because of copper or aluminum electrical resistance) and parallel conductance to ground via non perfect isolator(s).
Said this, and ignoring me about the aerial you are asking for, it seems too complicated and expensive, requiring several adjustements, and then, critical. More over if you will use it with semiconductor power stage, some times delicated with SWR. It is more easier and cheaper to build an antenna for your own, and the satisfaction when results appears.
May I suggest one of this easy to build aerial? Take a common AC wiring of such long as half wave of the lower frequency you want to TX&RX. Get two isolators for dipole, here in Argentina are called "
aislador huevo" (egg isolator, pic below).
Thus, own a ferrite core of AM transistor radio or a large toroidal core. Build on it an autotransformer of, say, 20:1 turns ratio of wire of sufficient wire diammeter to support RF currents. Turns may be a bit separated in order to reduce intrawinding capacitance. Hook the coax to the smaller winding, live to tap and shield to shorter end. This will cause to be a step up autotransformer, both voltage (20:1) and impedance (20²:1 or 400:1 ), giving 400 × 50R or about 2KR to ONE END of the dipole. Ground the outer conductor and autotraffo common return if possible.
Thus, this model will operate at, say, half wave at 80m (40m of continuous wire), a wave at 40m, twice wave at 20m, etc without changing anything. The lobes modifies as the size of the wire changes respect to the wave long. But in any instance you will comunicate perfectly without headaches.
The remote end of the wire remains isolated, as far from conducting objects as possible.
Cut small pieces of wire, longuer first, shortes after to find proper resonance. During adjust, use low power to avoid core saturation if SWR is large.
Finally protect the autotraffo using a discarded mermelade glass jar, open end looking down.
I used this topology some years ago when I still live at dad and mum's house with my FT767. The wire was located diagonally over the street, and remote end in a telephone pole.
Osvaldo LW1DSE from Argentina.
