Edit:- eBay link to image no longer valid 23/11/25
I took a punt on one of these, thinking that it might be ok for portable use whenever, and I got the medium sized one.
I hadn't read the description that says they need to be self assembled so was surprised to get a bag of parts eventually, but putting it together wasn't too difficult, after looking at the pictures in the listing again. There were no instructions.
The good:
It is a nice size when assembled.
It came with 4 small magnets for the base.
The bad:
It is made up of rather roughly 3D printed parts, and some machine screws which appear to be brass. However, the screws fix directly to the plastic and have to tap their own thread, which means it is not a good long term secure fit.
When assembled, the paddles wobble and rotate in directions they're not supposed to. The paddles are screwed vertically to the base with machine screws, but there is lateral movement at the top and the feel when squeezing the tops of the paddles is more sloppy than when squeezing the bottom.
The central post that the paddles make contact with is screwed up vertically from the bottom, but on mine it wasn't actually perpendicular to the base and as a result the adjustment was poor and not the same for both sides and it felt uneven when using it.
Overall:
I know this was made to a (very low) price, and it shows. The thing is that it took 6 weeks to get to me, came without any instructions and to make it actually feel nice to use would take more work than the key is worth. It's interesting as a curiosity, but that's it.
The good:
The bad:
Overall:
