As some of you may know, I'm a great admirer of the QSK llc, TP-1 Touch Paddle but it's a bit expensive for me at £190 delivered.
I've been doing some experiments with transistors, partly because I'm trying to learn some electronics and partly because I had this idea to modify my CW Beacon as a touch keyer using transistors instead of relays. Almost by accident, I seem to have come up with this device (images below). It looks too simple to work at all but, amazingly, it works very well! I've tried it out on Vail and CWCOM and it works without any adjustments to settings.
I already had the two 2N2222 general purpose transistors and the 1000 ohm resistors (they cost pence anyway). And the stereo lead cost £1 (from Kitronics). The rest of it was laying about the Man Cave (the self-adhesive copper tape is used in the garden as a not-very-effective slug repellent).
As I hope you can see, the transistor Base is connected through the resistor to the conductive pad. The Emitters are connected together and go to the earth connection on the "sleeve" of the TRS jack. The Collectors are the output: the left one goes to the "tip" of the jack (dits); the right one goes to the "ring" of the jack (dahs). The touch key jack is plugged into my Kanga K-16 keyer and that plugs into your radio or whatever else you're using to send morse.
You can tell, I'm dead chuffed - for a £1 and a very pleasant hour tinkering at my workbench, I have a very good capacitive touch double paddle.
