Bug Keys - buying secondhand
Jun 27, 2020
196
I have a morse buddy (a straight key guy) who recently bought a used presentation Vibroplex Bug for only £50. It did have some issues so he stripped it down and cleaned and serviced it. Not only does it now look stunning, he also seems to have taken to it like the proverbial duck to water.
But I've also heard it said that secondhand bug keys can have many traps for the unwary. Would anyone care to offer tips to a prospective purchaser on how to avoid (or overcome) the typical pitfalls?
There are several things to look out for with bug keys of any make, of which the following points come to mind...
1) Is The Key Complete?
It may seem obvious but sometimes parts do go missing, either because they simply fell off or got broken, or else one of the previous owners removed them. Some items can be replaced easily, like missing or worn feet, but other parts like the vibrating arm, contacts and the like can be more difficult to find. Vibroplex I think still offer some spares for the more common keys they produce, but I would guess that this would only cover keys that are in production. The most common missing parts are the paddle/button 'plastics', the tuning lever, weights, connecting post screws.
2) Is The Key Worn Excessively?
Wear on bug keys varies a lot. I have seen 100yr old ones with hardly any wear at all, whereas others which have been only a few years old have had excessive wear. The number one main item to check is the pivot that supports the swinging arm. The arm, when the key is viewed from the side should run parallel to the base. If you see a bug where the arm seems to slope backwards towards the damper then it is a sure sign the main pivot is either out of adjustment (easily remedied), or worn badly (not so easy to fix if indeed at all). Apart from the main bearing or pivot, another thing that can cause apparent tilt is where the riveted joint at the middle of the arm has been strained or forced, causing it to not be lined up with the rest of the arm. The main causes of this are either excessive weight being added to the arm to slow the key down, or very often due to rough handling of the key by previous owners. The riveted joint can also go out of alignment when the key has been dropped on its base, the result being that the weights jerk downwards causing damage. So long as the joint is tight it can very often simply be pulled back in to alignment, or else the arm assembly removed and tapped back in to alignment with a small hammer. Some I have seen over the years have become completely loose, and these may need the rivets tapped back down to close the gap and improve the grip. If the key is not particularly valuable then it is also possible to just use a little super glue on the joint, making sure the assembly is aligned before the glue sets.
3) Is The Split Arm Pivot Point Worn Excessively?
Apart from the main arm pivot, there is a second area that can wear and that is the split arm pivot. On pretty well all bug keys that follow the Vibroplex pattern, the swinging arm is formed from two pieces. The two are held together by a vertical rod (the pointed ends of which form the main needle bearing for the arm assembly), the larger part of the arm is clamped to the rod, with a shorter 'floating' section that pivots around the rod. If you push the arm to produce dits then the two parts move together, pivoting on the needle points, when pushed to produce dahs the main long section of the arm does not move, just the shorter arm pivoted around the vertical rod. Where this rotation occurs wear will develop over time, the result being that in severe cases there will be excessive vertical movement of the shorter 'dah' arm. The arm will appear to be a sloppy fit and feel loose. Although still useable the key just will not feel as crisp and positive as an unworn key. In really bad cases it will also cause erratic dah production due to the poor electrical contact between the shorter and long arm sections. It is pretty well impossible to correct this wear since it would involve added lost material. If you are equipped with a workshop however it may be possible to remove the original pivot rod and replace it with one of a larger diameter, and also re-drill the holes in the shorter arm. The replacement pivot rod also requires 'points' machined on each end to form the needle points for pivoting of the whole arm assembly. All in all a lot of work.
4) What Is The Overall Condition Like?
Stating the obvious, but does the key look OK? Does it have excessive corrosion or wear? Is it worth the money asked for it? The main issue generally after missing parts and pivot wear is corrosion and paint chipping. Once the protection of the chrome plating has gone rust spots will soon develop, and although it is possible to polish a key 'back' to produce an acceptable appearance, it will always be prone to the rust reforming on exposed areas. Saying that, all of this is mere cosmetic appearance, and will normally have no effect at all on the general performance of the key. I have seen some real 'rust buckets' that have operated fine.
5) Postage and Packing
What has postage and packing to do with bug keys? Well, in short, a good deal. You have to first remember that the bases of most bug keys are very heavy, quite a few pounds in weight generally. That in itself is not an issue, but where problems arise is when a key is sent through the post that has not been correctly packed. I have had three bug keys badly damaged in the post due to rough handling, but that damage would not have occurred if an appropriate level of support had been provided by the packing, or by an even simpler solution: Removal of the arm before posting.
If you take a bug key and drop it with the lever downmost, when it impacts with the floor or some other solid object all of the weight of the base of the key is transferred through the main arm pivot. Although well made, this massive impact will destroy the bearing points in an instant, or at least badly damage the points/rod. It has to be the saddest moment when you unpack a bug key to find that the arm has been pushed straight out of the back end by impact damage!
Yet it can be avoided so easily. The very easiest method is to remove the arm assembly and pack it separately (within the same package of course). If the arm is removed it cannot get damaged if the package is dropped.
Another way is to leave the arm attached, but make a packing ring to fit around the arm in such a manner so that if the key is dropped end on, the packing ring will absorb the impact, not the arm pivot.
Another method I have used when sending bugs through the post is to create a tough triangular 'tube' out of corrugated card (think of a Toblerone box), and then lock the key in place within the tube using large cable ties. Again, an end on impact will not damage the arm as the force will be distributed through the ties (think of how a seat belt works).
If you do see a bug key up for grabs, always try to find some reference images from other sources to compare it to. You would be surprised how many keys are actually 'Franken-keys', composed of pieces of two or more keys. Also it will give you a good idea if anything is missing or has been 'modded' for whatever reason.
Most of the Vibroplex keys can be loosely dated by their serial numbers, but an old key will not necessarily be a poor key, and conversely a relatively new key might not be as perfect as you think. It is always best to examine the key in question first hand if at all possible. Failing that, worse case scenario is that you will acquire a 'novelty doorstop' for your shack!
foggycoder said:
Thanks for that. It certainly makes for sobering reading. Caveat Emptor, I guess.
Mmmm, not so much beware, just observant. If you really want a good quality bug, and were worried about possible flaws, the only real solution would be to purchase one brand new.
Having said that, I have six or seven assorted ones, and none of them were purchased new, all were second (or more) hand items. In nearly every case the keys just needed stripping down and cleaning, with a little lubrication on the pivots while reassembling. Some have slight wear to the dah arm pivot, but no more than you might expect for a 70-80 year old key!
It is probably the bit that takes the most hammering in bugs, the pivot points, due to the weights involved and the side strain. But they are tough little guys, and unless dropped they will normally see several operators out without so much as needing a clean!
For example, the Vibroplex Original Deluxe model I purchased looked a total wreck in the photos, there was so much dirt and dust on it the key looked to be 150 years old. However, when it arrived, I could see that all of the 'ageing' was just surface grime and dust. So, a full strip down of the key, some detergent and then polishing, and it came up a treat. If I had have purchased one new it would have cost around four times the price! :o
Whereas a lot of other keys can be purchased quite cheaply, bugs will very often command a price well above what you might expect. I've seen some sellers asking 150% more for a second hand key than what they cost new. Time to move on I would say...
In the UK, because they are rarer keys here, they prices are very often quite high. If you search eBay for bug keys in the States you will not only get a far greater range to choose from, but the prices are normally much better. Very often you can buy a second hand Vibroplex from the States, and even with any duty and taxes added, and the postage costs, you can still obtain them cheaper than the equivalent from the UK!
No matter where you purchase one from, I would always ask the seller to remove the arm and pack it separately within the box so as to avoid the impact damage mentioned in my previous post. It only requires them to slacken off the pivot screws and the arm can be lifted out (sometimes the weights will need sliding off the arm to allow it to pass through the frame).
So yeah, be observant, if you really like a key ask the seller if they have any more photos, or could they take some. The main one is a side view so as to allow you to check the state of the pivots and the riveted joint in the arm (again, as mentioned in my previous post). Just one photograph from the side can tell you lots about a key. And if you do ask them to take a side shot of a key, don't tell them why you want it. If you say it's to check the pivot/riveting  then they may well fudge the photograph to make the key appear better than it is!
My experience on bugs is limited to the Lionel J-36 (copy of the Vibroplex Lightning) , the McElroy Deluxe, and the current bug a 1945 Vibroplex Original (has a steel nameplate as brass was needed for the war effort).
They do vary a bit in how slow they can go. You can of course slow them down with heavier weights or by extending the weight arm but this also alters the feel, and not in a good way. The stiffness of the vibrating arm apparently varies too.
On eham a lot of people rate the Lightning and it's clones as an easier bug to master as it will go slower than an Original. I would agree with that view. The Champion is essentially a Lightning with a simplified damper.
I like the look of the KN4YB right angled key.
https://www.facebook.com/rightanglebugkey/
There are youtube videos showing how slow it can go which are quite impressive.
I had a look at that KN4YB right angle bug. I don't do Facebook so I went to http://www.kn4yb.com/rightanglesingle.html , and I've attached an image of it for reference.
Now that is definitely my sort of paddle! If I was going to have a bug and I had the money (he doesn't give the price, which tells you straight away that its going to be horrendously expensive...plus the shipping, plus the tax, plus the Post Office handling charge), then this is what I'd want. I'm smitten!
GM0WEZ said:
You can of course slow them down with heavier weights or by extending the weight arm but this also alters the feel, and not in a good way...
...I like the look of the KN4YB right angled key...
But surely the reason that it is able to operate so slowly is due to the length of the arm (which appears to have an extender fitted).
So would not the 'feel' of that key also be impaired?  :-*
foggycoder said:
I had a look at that KN4YB right angle bug...
http://vizkey.com/order.html
Yes, that K4VIZ 90 degree VIZBUG seems to be a good price at $220 plus the extras. But it's a bit "brassy" for my taste - I prefer the slightly understated look of the KN4YB bug (I have expensive tastes but modest resources - it's a recurring theme in my life).
I see that K4VIZ also does the VIZ-'Cootie' for $110 plus the extras. I looks functionally identical to my hacksaw blade single paddle which cost me a tenth of that.
Search Google for "mecograph" then... bd
You could always drop G3YUH an email and get a quote for one from him. I know he makes bug keys (I have one here), and I'm sure I've seen him selling those right-angled bugs on eBay too.
I've read that the right angle design is actually better for handling as the base is more stable against force exerted in that direction. Never tried one to verify.
I agree the KN4YB looks a lot nicer than the Vizkey. The black crackle paint is very understated.
Although I expect the extending arm on the KN4YB might well impair feel, you have to remember that it will go crazy slow (10wpm I think - so slow I would prefer a straight key at that speed) with the extension. My vibroplex only goes down to about 22wpm with an extension. So I think the KN4YB would still be sufficiently slow for many ops without using the extension arm.
I had another look at the KN4YB website (yes, I'm my own worst enemy) and the price of his right-angled bug is on there - $175 plus $25 extra shipping (plus tax and handling at this end). So not so expensive after all.
Go on, treat yourself!
A right-angled bug at the right (angled) price. You deserve it!  bd
The cost of a KN4YB right-angled bug is equivalent to four months pocket money (assuming I don't get distracted by other toys in the meantime). I shall have to be very well behaved and write a nice neat letter to Father Christmas.
The above quote is a much shortened version of my original reply, edited for brevity.
Well, I took my own advice while viewing/purchasing a second hand bug (yes, another one). For about 10-15 yrs or so now I have been on the lookout for a Vibroplex Blue Racer. No special reason other than I like the look of them. pq
I spotted one for sale that looked excellent, and more importantly, it has one of the original style embossed Vibroplex badges/serial number plates, not one of those naff looking screen printed ones they fit nowadays.
You can buy them new (when any dealers have stock of them over here in the UK), but the price for a new one has always seemed a little high. With the one I purchased (which looks like new and appears to have had little or no use), even allowing for the postage and import fees (all sorted out before hand by eBay's global shipping system), it still comes in with a massive saving over buying one in the UK. :*:
Not sure how long it will take to arrive, though items tend to take about 10-14 days I've found from the States. Hopefully, if it arrives in one piece  :*: C:-) I'll post a few photos of it.
Here's a video of one being put through its paces by JN4XIZ on YouTube... https://www.youtube.com/watch?v=KgDNLd4C3Qk
Now for the waiting bit!  :o
